Olá,
Segue o fluxo de como está!
[{"id":"6fbe1e218710a4e4","type":"group","z":"e2e359eced03b574","name":"CORREIOS HA - NOVO","style":{"fill":"#c8e7a7","label":true,"stroke":"#000000","color":"#000000"},"nodes":["dc61963ce89baa06","e31f552e5f254abb","6c89c688dc97e0e5","8db766b066f5f21b","59e80d6f8f2ba3f2","c44ed408a2f93817","8f0f28c7cb72d267","ad3b29be64ad15dd","1b07711cdf1b01b5","79cf29c8e384fc39","d38304c45a10ce76"],"x":54,"y":899,"w":1232,"h":262},{"id":"dc61963ce89baa06","type":"server-state-changed","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"VERIFICA","server":"48089071.a66eb","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"_correios_","entityidfiltertype":"regex","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":140,"y":1000,"wires":[["59e80d6f8f2ba3f2"]]},{"id":"e31f552e5f254abb","type":"template","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"MENSAGEM","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"🔻 Atualização de pacote 🔻\n📦 {{data.new_state.attributes.friendly_name}} \n\n📌 {{payload}}\n📤 De: {{{data.new_state.attributes.Origem}}}\n📥 Para: {{{data.new_state.attributes.Destino}}}\n📆 {{data.new_state.attributes.Última Movimentação}}","output":"str","x":950,"y":1120,"wires":[["8db766b066f5f21b"]]},{"id":"6c89c688dc97e0e5","type":"change","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"CORRIGE NOME","rules":[{"t":"change","p":"data.new_state.attributes.friendly_name","pt":"msg","from":"correios","fromt":"str","to":"","tot":"str"},{"t":"change","p":"data.new_state.attributes.Descrição","pt":"msg","from":"correios","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":1000,"wires":[["c44ed408a2f93817"]]},{"id":"8db766b066f5f21b","type":"telegrambot-notify","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"ENVIA MSG","bot":"a8c7e8f2.97aaf8","chatId":"-458880638","message":"","parseMode":"","x":1190,"y":1000,"wires":[]},{"id":"59e80d6f8f2ba3f2","type":"switch","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"FILTRO","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"unavailable","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":280,"y":1000,"wires":[["6c89c688dc97e0e5","d38304c45a10ce76"]]},{"id":"c44ed408a2f93817","type":"switch","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"STATUS","property":"data.new_state.state","propertyType":"msg","rules":[{"t":"eq","v":"SRO-020: Objeto não encontrado na base de dados dos Correios.","vt":"str"},{"t":"eq","v":"Objeto postado","vt":"str"},{"t":"eq","v":"Objeto recebido pelos Correios do Brasil","vt":"str"},{"t":"eq","v":"Objeto entregue ao destinatário","vt":"str"},{"t":"eq","v":"Objeto saiu para entrega ao destinatário","vt":"str"},{"t":"eq","v":"Objeto em trânsito - por favor aguarde","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":660,"y":1000,"wires":[["ad3b29be64ad15dd"],["8f0f28c7cb72d267"],["8f0f28c7cb72d267"],["8f0f28c7cb72d267"],["8f0f28c7cb72d267","1b07711cdf1b01b5"],["e31f552e5f254abb"]]},{"id":"8f0f28c7cb72d267","type":"template","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"MENSAGEM","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"🔻 Atualização de pacote 🔻\n📦 {{data.new_state.attributes.friendly_name}} \n\n📌 {{payload}}\n📤 De: {{{data.new_state.attributes.Origem}}}\n📆 {{data.new_state.attributes.Última Movimentação}}","output":"str","x":950,"y":1000,"wires":[["8db766b066f5f21b"]]},{"id":"ad3b29be64ad15dd","type":"template","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"MENSAGEM","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"📦 {{data.new_state.attributes.friendly_name}} \n⏰ Aguardando atualizações do objeto","output":"str","x":950,"y":940,"wires":[["8db766b066f5f21b"]]},{"id":"1b07711cdf1b01b5","type":"function","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"Saiu para entrega","func":"msg.payload = \"O objeto \" + msg.data.new_state.attributes.Descrição + \" saiu para entrega\"\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":970,"y":1060,"wires":[["79cf29c8e384fc39"]]},{"id":"79cf29c8e384fc39","type":"api-call-service","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"Alexa TTS","server":"48089071.a66eb","version":5,"debugenabled":false,"domain":"notify","service":"alexa_media_echo_sala","areaId":[],"deviceId":[],"entityId":[],"data":"{\t \"message\":msg.payload,\t \"data\":{\"type\":\"announce\"}\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1190,"y":1060,"wires":[[]]},{"id":"d38304c45a10ce76","type":"debug","z":"e2e359eced03b574","g":"6fbe1e218710a4e4","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":460,"y":1100,"wires":[]},{"id":"48089071.a66eb","type":"server","name":"Home Assistant","version":4,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m"},{"id":"a8c7e8f2.97aaf8","type":"telegrambot-config","botname":"Jarvis Cespedes - Node RED","usernames":"","chatIds":"924407960, 1823728078, -458880638, -709566795","pollInterval":"300"}]
