Nao consigo iniciar o samba share.
Fiz a instalação dele, coloquei username e senha, aperto para iniciar mas o status continua vermelho(add-on está parado).
Estou usando Windows 10
O que tem no log? Coloca aqui
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-smbd: starting
[20:18:04] INFO: Hostname: homeassistant
[20:18:05] INFO: Interfaces: wlan0 eth0
addgroup: illegal character with code 195 at position 1
s6-rc: warning: unable to start service init-smbd: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Verifica se não é algum caracter especial na senha ou usuário
