[{“id”:“128a2f40.60ab29”,“type”:“server-state-changed”,“z”:“180ed205.535f36”,“name”:“sensor.current”,“server”:“1a7fb63e.b9421a”,“version”:1,“exposeToHomeAssistant”:false,“haConfig”:[{“property”:“name”,“value”:""},{“property”:“icon”,“value”:""}],“entityidfilter”:“sensor.current”,“entityidfiltertype”:“exact”,“outputinitially”:false,“state_type”:“num”,“haltifstate”:“0”,“halt_if_type”:“str”,“halt_if_compare”:“is_not”,“outputs”:2,“output_only_on_state_change”:true,“x”:160,“y”:960,“wires”:[[“a32d35b1.8bb498”,“499e7229.27ec54”],[]]},{“id”:“499e7229.27ec54”,“type”:“function”,“z”:“180ed205.535f36”,“name”:“FUNCÃO OK”,“func”:“var topic = msg.topic;\nvar corrente = context.previcorrente;\nvar pressao = context.previpressao;\nvar diames= msg.mydate;\n\n\nvar previcorrente = context.previcorrente;\nvar previpressao = msg.payload;\n\n\n\nif (topic == “sensor.current”){\n msg.topic= “corrente”;\n corrente = msg.payload;\n context.previcorrente = corrente;\n}\n\nif (topic == “sensor.pressao_agua_rede”){\n msg.topic= “pressao”;\n pressao = msg.payload;\n context.previpressao = pressao;\n}\n\nif (corrente>= pressao){\n \n msg.payload = “recebeu topico :” + topic +” a corrente é maoir que a pressão corrente : " + corrente + " pressao : " + pressao;\n}else {\n \n msg.payload = “recebeu topico :” + topic +" a pressao é maoir que a corrente corrente : " + corrente + " pressao : " + pressao; \n}\n\nreturn msg;\n",“outputs”:1,“noerr”:0,“initialize”:"",“finalize”:"",“x”:370,“y”:980,“wires”:[[“33db1204.45323e”]]},{“id”:“16895548.1627fb”,“type”:“server-state-changed”,“z”:“180ed205.535f36”,“name”:“sensor.pressao_agua_rede”,“server”:“1a7fb63e.b9421a”,“version”:1,“exposeToHomeAssistant”:false,“haConfig”:[{“property”:“name”,“value”:""},{“property”:“icon”,“value”:""}],“entityidfilter”:“sensor.pressao_agua_rede”,“entityidfiltertype”:“exact”,“outputinitially”:false,“state_type”:“num”,“haltifstate”:“0”,“halt_if_type”:“num”,“halt_if_compare”:“is_not”,“outputs”:2,“output_only_on_state_change”:true,“x”:120,“y”:1000,“wires”:[[“ae65db7e.ad8fb”,“499e7229.27ec54”],[]]},{“id”:“a32d35b1.8bb498”,“type”:“debug”,“z”:“180ed205.535f36”,“name”:"",“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“targetType”:“full”,“x”:330,“y”:940,“wires”:[]},{“id”:“ae65db7e.ad8fb”,“type”:“debug”,“z”:“180ed205.535f36”,“name”:"",“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“targetType”:“full”,“x”:330,“y”:1020,“wires”:[]},{“id”:“33db1204.45323e”,“type”:“debug”,“z”:“180ed205.535f36”,“name”:"",“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“true”,“targetType”:“full”,“x”:510,“y”:980,“wires”:[]},{“id”:“43594260.78dd0c”,“type”:“comment”,“z”:“180ed205.535f36”,“name”:“Compara dois sensores e grava mensagem”,“info”:"",“x”:190,“y”:900,“wires”:[]},{“id”:“1a7fb63e.b9421a”,“type”:“server”,“z”:"",“name”:“Home Assistant”}]
Estou com algumas dificuldades porque as “” são alteradas e não posso enviar ficheiros de txt ou json.
Lamento
![:disappointed_relieved: :disappointed_relieved:](https://forum.homeassistantbrasil.com.br/images/emoji/apple/disappointed_relieved.png?v=9)
