Pessoal, tudo bom?
Alguém já passou por esse problema, com dispositivos da NovaDigital que rodam na Tuya? Apenas produtos da NovaDigital que estou tendo esse problema, de outras marca consegui adicionar no LocalTuya.
This error originated from a custom integration.
Logger: custom_components.localtuya.config_flow
Source: custom_components/localtuya/config_flow.py:595
Integration: LocalTuya (documentation, issues)
First occurred: October 16, 2023 at 9:08:12 PM (1 occurrences)
Last logged: October 16, 2023 at 9:08:12 PM
Unexpected exception: [Errno 113] Connect call failed ('192.168.5.62', 6668)
File "/config/custom_components/localtuya/config_flow.py", line 595, in async_step_configure_device
self.dps_strings = await validate_input(self.hass, user_input)
File "/config/custom_components/localtuya/config_flow.py", line 242, in validate_input
interface = await pytuya.connect(
File "/config/custom_components/localtuya/pytuya/__init__.py", line 1182, in connect
_, protocol = await loop.create_connection(
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1085, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1069, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 973, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 628, in sock_connect
return await fut
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 668, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.5.62', 6668)
