lokss
Fevereiro 19, 2023, 12:16pm
1
Amigos, tenho em minha casa 3 micro inversores APSystems DS3D sendo monitorados por uma ECU-R.
Alguém já fez este tipo de integração ?
Achei esta documentação mas não sei nem por onde começar…
[](https://github.com/hacs/integration)
[](https://github.com/ksheumaker/homeassistant-apsystems_ecur)
[](https://github.com/ksheumaker/homeassistant-apsystems_ecur/actions/workflows/validate%20with%20Hassfest.yml)
# Home-Assistant APsystems ECU Integration
This is an integration for [Home-Assistant](http://home-assistant.io) that adds support for the [APsystems](http://www.apsystems.com) Energy Communication Unit (ECU) so that you are able to monitor your PV installation (inverters) in detail. It currently supports one ECU (one instance of the integration) but a work-around is available https://github.com/ksheumaker/homeassistant-apsystems_ecur/issues/142
Note: This integration was initially written for the older ECU-R (2160xxxxxxxx series) and is fully compatible with the ECU-B. For later ECU-R models (SunSpec logo/ECU-ID starting with 2162xxxxxxxx) and ECU-C owners, usage of this integration results in ECU outage over time. From version 1.2.21 the integration will restart the ECU automatically. This can be monitored by the "binary_sensor.restart_ecu". Unfortunately this is a firmware issue which can't be solved by the integration.
## Background & acknowledgement
This integration queries the ECU with a set interval for new data. This was done without a public API, and by listening to and interpreting the protocol the APSystems ECU phone app (ECUapp) uses when setting up the PV array. This couldn't have been done without the hardwork of @checking12 and @HAEdwin on the home assistant forum, and all the other people from this forum (https://gathering.tweakers.net/forum/list_messages/2032302/1). Thanks goes out to @12christiaan and @ViperRNMC for providing an automated solution to restart the ECU-C and ECU-R (SunSpec logo/ECU-ID starting with 2162xxxxxxxx) models.
## Prerequisites
You own an APSystems ECU model ECU-B, ECU-R or ECU-C and any combination of YC600, YC1000, DS3/DS3D or QS1/QS1A inverter. Your ECU is connected to your LAN, correctly configured (assigned a fixed IP address) and Home Assistant has free access to it. You also have HACS installed in Home Assistant.
Connection method (ethernet or WiFi) depends on your ECU model, follow the table below.
Connection | ECU Model | Automated Restart*
This file has been truncated. show original
Alguém para ajudar ?
tbm estou querendo fazer o mesmo
lokss
Março 15, 2023, 7:47pm
3
Conseguiu ? Eu segui os passos e consegui.
