Meu HA esta reinciando sozinho, isto começou hoje e nao para… quando consigo entrar e vou tentar ver o LOG ele ja reincia.
Alguem tem uma dica pra dar ?
Se tiver o samba instalado, você consegue acessar o diretório mesmo com ele reiniciando. Sabe qual mudança fez que pode estar causando?
Opa obrigado por responder… e desculpa a demora eu precisei viajar…
Mas eu nao fiz nada nos ultimos dias… instalei uma integração ONVI, mas ja removi e mesmo assim ele reinicia do nada… e nao atualiza por nada…
Versão instalada
2024.6.2
Última versão
2024.6.3
Segue meu ultimo LOG.
2024-06-18 07:34:31.188 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-06-18 07:34:31.202 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration moonraker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-06-18 07:34:31.208 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration rpi_gpio which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-06-18 07:34:31.214 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration yooseeptz which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-06-18 07:34:31.220 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-06-18 07:34:35.173 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-06-18 07:34:36.296 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=329 from 2024-06-18 10:27:35.866434)
2024-06-18 07:35:01.092 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration ‘hacs’ accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at Issues · hacs/integration · GitHub
2024-06-18 07:35:04.609 WARNING (MainThread) [custom_components.moonraker] Cannot configure moonraker instance
2024-06-18 07:35:04.612 ERROR (MainThread) [moonraker_api.websockets.websocketclient] Websocket connection error: Cannot connect to host 192.168.15.153:7125 ssl:default [Connect call failed (‘192.168.15.153’, 7125)]
2024-06-18 07:35:07.432 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration ‘alexa_media’ accesses hass.helpers.instance_id. This is deprecated and will stop working in Home Assistant 2024.11, it should be updated to import functions used from instance_id directly at custom_components/alexa_media/helpers.py, line 274: uuid = await hass.helpers.instance_id.async_get(), please create a bug report at Issues · alandtse/alexa_media_player · GitHub
2024-06-18 07:35:17.737 WARNING (SyncWorker_2) [homeassistant.components.rpi_power.binary_sensor] Under-voltage was detected. Consider getting a uninterruptible power supply for your Raspberry Pi.
2024-06-18 07:35:18.542 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration ‘alexa_media’ calls async_add_job
, which is deprecated and will be removed in Home Assistant 2025.4; Please review Deprecating `async_run_job` and `async_add_job` | Home Assistant Developer Docs for replacement options at custom_components/alexa_media/init.py, line 625: hass.async_add_job(, please create a bug report at Issues · alandtse/alexa_media_player · GitHub
2024-06-18 07:35:19.559 ERROR (MainThread) [homeassistant.components.automation] Automation with alias ‘Temdeabrirpersiana’ failed to setup triggers and has been disabled: Unknown device ‘283870a09c8aa6cd8db4bb6a8d126e86’
2024-06-18 07:35:19.562 ERROR (MainThread) [homeassistant.components.automation] Automation with alias ‘tempfechapersiana’ failed to setup triggers and has been disabled: Unknown device ‘283870a09c8aa6cd8db4bb6a8d126e86’
2024-06-18 07:35:20.671 ERROR (MainThread) [homeassistant.components.automation] Automation with alias ‘Portaochamando’ failed to setup triggers and has been disabled: Unknown device ‘1b8102ceafa49f2714b5f0af1e5d7a17’
2024-06-18 07:35:21.707 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration ‘alexa_media’ calls async_add_job
, which is deprecated and will be removed in Home Assistant 2025.4; Please review Deprecating `async_run_job` and `async_add_job` | Home Assistant Developer Docs for replacement options at custom_components/alexa_media/media_player.py, line 188: hass.async_add_job(, please create a bug report at Issues · alandtse/alexa_media_player · GitHub
2024-06-18 07:35:22.426 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open inside the event loop by custom integration ‘alexa_media’ at custom_components/alexa_media/sensor.py, line 450: timezone = pytz.timezone( (offender: /usr/local/lib/python3.12/site-packages/pytz/init.py, line 108: return open(filename, ‘rb’)), please create a bug report at Issues · alandtse/alexa_media_player · GitHub
Não sei onde esta o problema… Ele não atualiza e não para de reinicar…
Tudo indica que é justamente a integração do hacs que está causando o problema. Parece que você não a desinstalou completamente. Você não tem um backup para restaurar?
Mas esta integração esta instalada desdo primeiro dia que configurei o HA… e sempre funcionou… alias… ela que controla todas as luzes da casa… Pois antes do HA eu tinha outra interface e Usava um modulo de rele solido para controlar a iluminação… eu mantive o modulo. usando a RPI_GPOI e acionando o modulo diretamente pelos pinos do RPI. e sempre funcionou.
Ata… e só lembrando que eu nao consigo atualizar…
Muitos erros no seu log. HA tem muito break change, não é pq uma integração funcionou no passado que sempre vai funcionar.
Pode ser sua fonte. Testa outra e tenta corrigir os erros do seu log, mesmo que seja desativando essas integrações temporariamente.
Provavelmente vc vai precisar colocar um teclado no RPI e tentar fazer isso via linha de comando.
Opa, Obrigado !
Apesar de usar uma fonte chaveada de PC, vou trocar a fonte…
Sobre as integrações nem sempre funcionar é complicado… quebra um ppouco a confiança no sistema, pois imagina fazer um investimento baseado em uma integração simples e não poder confiar que ela vai funciona sempre?
Eu migrei do domoticz para o HA por causa da estabilidade e da integração com ALEXA gratuita… mas ta osso… rsrs
Vou realizar mais testes…
No rpi4 que usava só parou de dar aviso com a fonte original.
O rpi4 pelo menos precisa de um pouco mais que 5v.
No seu caso é só para teste, não quer dizer que seja uma integração.
Vc usa SDCARD ou SSD?
Normalmente as integrações dão problema nos updates, tem que ficar ligado nos break changes do HA ou pode ser um bug na atualização.
Minha recomendação é nunca atualizar o HA, adddon etc assim que sai uma versão nova, espera alguns dias.
Mas no geral o HA é bem estável e confiável, mas tem que ficar ligado nas mudanças que eles fazem.
Da uma olhada no update de ontem:
