Amigos
Comprei modulo Esp32cAM COM Esp32-cam-mb micro usb
Quero integrar no ESPHOME
Uso o codigo
esphome:
platform: ESP32
board: esp32dev
Enable logging
logger:
Enable Home Assistant API
api:
reboot_timeout: 0s
ota:
web_server:
port: 80
wifi:
ssid: !secret wifi_ssid
Optional manual IP
manual_ip:
static_ip: 192.168.1.135
gateway: 192.168.1.1
subnet: 255.255.255.0
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Esp32-Cam Fallback Hotspot”
password: “tdsdsdadasdsadsadsadasdasd”
captive_portal:
Example configuration entry
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
Image settings
name: My ESP32-CAM
Flashlight
output:
- platform: gpio
pin: GPIO4
GPIO_4 is the flash light pin
light:
- platform: binary
output: gpio_4
#WiFi Signal Sensor
- platform: wifi_signal
name: EspCam wifi signal
update_interval: 30s
unit_of_measurement: “dBa”
accuracy_decimals: 0
O led funciona da esp32cam - o webserver tbm
mas imagem que é o principal. Não
fica um alera vermelho na entidade .
Preciso de ajuda
Segui o video
