Pessoal, boa tarde. Estou começando a conhecer o HA.
Estou tentando fazer uma instalação, e sempre recebo um erro, me perdoem se colocar da forma errada.
Vi que no forum internacional tem pessoas com o mesmo erro.
Downloading atomicwrites_homeassistant-1.4.1-py2.py3-none-any.whl (7.1 kB)
Collecting orjson==3.7.5
Using cached orjson-3.7.5.tar.gz (640 kB)
Installing build dependencies ... error
error: subprocess-exited-with-error
× pip subprocess to install build dependencies did not run successfully.
│ exit code: 1
╰─> [45 lines of output]
Collecting maturin<0.13,>=0.12.19
Using cached maturin-0.12.20.tar.gz (156 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Collecting tomli>=1.1.0
Using cached tomli-2.0.1-py3-none-any.whl (12 kB)
Building wheels for collected packages: maturin
Building wheel for maturin (pyproject.toml): started
Building wheel for maturin (pyproject.toml): finished with status 'error'
× Building wheel for maturin (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [21 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.10
creating build/lib.linux-armv7l-3.10/maturin
copying maturin/__init__.py -> build/lib.linux-armv7l-3.10/maturin
copying maturin/import_hook.py -> build/lib.linux-armv7l-3.10/maturin
running build_ext
running build_rust
error: can't find Rust compiler
If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
To update pip, run:
pip install --upgrade pip
and then retry package installation.
If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for maturin
Failed to build maturin
ERROR: Could not build wheels for maturin, which is required to install pyproject.toml-based projects
[end of output]
│ exit code: 1
╰─> See above for output.
