Não vejo nada nos addons de uma nova instalação do Hassio.
Instalei em um Raspberry Pi 4b, com Raspbian e docker.
Segue o erro que dá ao iniciar:
Bloco de Citação
20-03-03 10:32:20 ERROR (MainThread) [hassio.store.git] Can’t clone https://github.com/home-assistant/hassio-addons repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/hassio-addons /data/addons/core
stderr: 'Cloning into ‘/data/addons/core’…
POST git-upload-pack (192 bytes)
POST git-upload-pack (201 bytes)
error: RPC failed; curl 56 OpenSSL SSL_read: Connection reset by peer
fatal: the remote end hung up unexpectedly
fatal: protocol error: bad pack header
20-03-03 10:32:20 ERROR (MainThread) [hassio.store] Can’t load from repository core
20-03-03 10:32:20 ERROR (MainThread) [hassio.store.git] Can’t clone GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v GitHub - hassio-addons/repository: Home Assistant Community Add-ons /data/addons/git/a0d7b954
stderr: 'Cloning into ‘/data/addons/git/a0d7b954’…
20-03-03 10:32:20 ERROR (MainThread) [hassio.store] Can’t load from repository GitHub - hassio-addons/repository: Home Assistant Community Add-ons
20-03-03 10:32:20 INFO (MainThread) [hassio.store] Load add-ons from store: 0 all - 0 new - 0 remove
20-03-03 10:32:20 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
20-03-03 10:32:20 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-03 10:32:20 WARNING (MainThread) [hassio.updater] Can’t fetch versions from https://version.home-assistant.io/stable.json: Cannot connect to host version.home-assistant.io:443 ssl:None [Address not available]
20-03-03 10:32:20 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
20-03-03 10:32:20 INFO (MainThread) [hassio.discovery] Load 0 messages
20-03-03 10:32:20 INFO (MainThread) [hassio.ingress] Load 0 ingress session
20-03-03 10:32:20 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 1
20-03-03 10:32:20 INFO (MainThread) [main] Run Hass.io
20-03-03 10:32:20 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
20-03-03 10:32:20 INFO (MainThread) [hassio.addons] Phase ‘initialize’ start 0 add-ons
20-03-03 10:32:20 INFO (MainThread) [hassio.addons] Phase ‘system’ start 0 add-ons
20-03-03 10:32:20 INFO (MainThread) [hassio.addons] Phase ‘services’ start 0 add-ons
20-03-03 10:32:20 INFO (SyncWorker_2) [hassio.docker.interface] Start homeassistant/raspberrypi4-homeassistant
20-03-03 10:32:41 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
20-03-03 10:32:41 INFO (MainThread) [hassio.addons] Phase ‘application’ start 0 add-ons
20-03-03 10:32:41 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
20-03-03 10:32:41 INFO (MainThread) [hassio.core] Hass.io is up and running
