Boa tarde a todos.
Sou novo aqui e preciso de uma ajuda.
Instalei o Home Assistant no Raspberry Pi 4, através do case oficial da rasp com um cooler. Porém ele fica ligado todo tempo.
Alguém sabe como faço para parametrizar as temperaturas para ela ligar e desligar?
Desde já obrigado.
Walber
Fevereiro 15, 2023, 6:37pm
2
Da uma olhada aqui:
Before you read this guide, please note that GPIO support was dropped from HA since release 2022.4. The solution still works, but needs an add-on installed through HACS. Try at your own risk, as there is always a chance of breaking HA when installing...
Reading time: 12 mins 🕑
Likes: 19 ❤
Dear folks, as I noticed that my Pi 4 4Gb became recently very hot, I upgraded my case by two fans. I used this nice guide but dicided to use one to blow cold air in and one to blow the hot air out: I used GPIO4, one 5v and one GND pin. Once...
Reading time: 8 mins 🕑
Likes: 22 ❤
Eu uso o case argon, ele tem um add-on para controlar a temperatura, mas não sei se funciona no seu case:
This is an addon for Argon One in Home Assistant. It’s essentially a script that runs in a docker container. It enables and automates the Argon One Active Cooling System with your specifications. Know your options There are two addons to choose...
Reading time: 79 mins 🕑
Likes: 124 ❤
