como posso evitar loop nessa automação?
como o comando para ligar e desligar é o mesmo botão acaba por ficar em loop
‘’‘[{“id”:“8071bec8c9fb0ae7”,“type”:“server-state-changed”,“z”:“e17ca6c3b32a21f8”,“g”:“3043ee2142704218”,“name”:“luz ventilador”,“server”:“40f09d9e1117eda5”,“version”:5,“outputs”:2,“exposeAsEntityConfig”:“”,“entityId”:“input_boolean.ligar_luz_do_ventilador”,“entityIdType”:“exact”,“outputInitially”:false,“stateType”:“str”,“ifState”:“on”,“ifStateType”:“str”,“ifStateOperator”:“is”,“outputOnlyOnStateChange”:true,“for”:“0”,“forType”:“num”,“forUnits”:“minutes”,“ignorePrevStateNull”:false,“ignorePrevStateUnknown”:false,“ignorePrevStateUnavailable”:false,“ignoreCurrentStateUnknown”:false,“ignoreCurrentStateUnavailable”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:“”,“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:“”,“valueType”:“eventData”},{“property”:“topic”,“propertyType”:“msg”,“value”:“”,“valueType”:“triggerId”}],“x”:110,“y”:1740,“wires”:[[“a27e8117ce8f89ce”],[“86535eee4297842f”]]},{“id”:“a27e8117ce8f89ce”,“type”:“api-call-service”,“z”:“e17ca6c3b32a21f8”,“g”:“3043ee2142704218”,“name”:“”,“server”:“40f09d9e1117eda5”,“version”:5,“debugenabled”:false,“domain”:“remote”,“service”:“send_command”,“areaId”:,“deviceId”:[“19d0ef5734295e8a3121a65937f7db70”],“entityId”:[“remote.broadlink_rm4_pro”],“data”:“{\t "device": "ventilador sala",\t"command": "ligar luz"\t}”,“dataType”:“jsonata”,“mergeContext”:“”,“mustacheAltTags”:false,“outputProperties”:,“queue”:“none”,“x”:1110,“y”:1720,“wires”:[]},{“id”:“86535eee4297842f”,“type”:“alexa-remote-routine”,“z”:“e17ca6c3b32a21f8”,“g”:“3043ee2142704218”,“name”:“”,“account”:“5c9f2c63485dd599”,“routineNode”:{“type”:“smarthome”,“payload”:{“entity”:“8894b0d7-bc2b-4ab3-8b2b-30f389848d62”,“action”:“sceneActivate”}},“x”:1100,“y”:1760,“wires”:[]},{“id”:“8bc4fe242848a141”,“type”:“switch”,“z”:“e17ca6c3b32a21f8”,“g”:“3043ee2142704218”,“name”:“Check power”,“property”:“payload”,“propertyType”:“msg”,“rules”:[{“t”:“btwn”,“v”:“2”,“vt”:“num”,“v2”:“12”,“v2t”:“num”},{“t”:“eq”,“v”:“0”,“vt”:“num”}],“checkall”:“true”,“repair”:false,“outputs”:2,“x”:470,“y”:1860,“wires”:[[“00f39eaa26163bdd”],[“a3ed689aa390fb1f”]]},{“id”:“00f39eaa26163bdd”,“type”:“api-call-service”,“z”:“e17ca6c3b32a21f8”,“g”:“3043ee2142704218”,“name”:“> 1 watt → define botão para ligado”,“server”:“40f09d9e1117eda5”,“version”:5,“debugenabled”:false,“domain”:“input_boolean”,“service”:“turn_on”,“areaId”:,“deviceId”:,“entityId”:[“input_boolean.ligar_luz_do_ventilador”],“data”:“”,“dataType”:“json”,“mergeContext”:“”,“mustacheAltTags”:false,“outputProperties”:,“queue”:“none”,“x”:1170,“y”:1840,“wires”:[]},{“id”:“823ce53833db5345”,“type”:“server-state-changed”,“z”:“e17ca6c3b32a21f8”,“g”:“3043ee2142704218”,“name”:“medidor de consumo do ventilador”,“server”:“40f09d9e1117eda5”,“version”:5,“outputs”:1,“exposeAsEntityConfig”:“”,“entityId”:“sensor.interruptor_do_ventilador_da_sala_potencia”,“entityIdType”:“exact”,“outputInitially”:false,“stateType”:“num”,“ifState”:“”,“ifStateType”:“str”,“ifStateOperator”:“is”,“outputOnlyOnStateChange”:true,“for”:“0”,“forType”:“num”,“forUnits”:“minutes”,“ignorePrevStateNull”:false,“ignorePrevStateUnknown”:false,“ignorePrevStateUnavailable”:false,“ignoreCurrentStateUnknown”:false,“ignoreCurrentStateUnavailable”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:“”,“valueType”:“entityState”}],“x”:180,“y”:1860,“wires”:[[“8bc4fe242848a141”]]},{“id”:“a3ed689aa390fb1f”,“type”:“api-call-service”,“z”:“e17ca6c3b32a21f8”,“g”:“3043ee2142704218”,“name”:“</= 0 watt → define botão para desligado”,“server”:“40f09d9e1117eda5”,“version”:5,“debugenabled”:false,“domain”:“input_boolean”,“service”:“turn_off”,“areaId”:,“deviceId”:,“entityId”:[“input_boolean.ligar_luz_do_ventilador”],“data”:“”,“dataType”:“json”,“mergeContext”:“”,“mustacheAltTags”:false,“outputProperties”:,“queue”:“none”,“x”:1180,“y”:1880,“wires”:[]},{“id”:“40f09d9e1117eda5”,“type”:“server”,“name”:“Home Assistant”,“version”:5,“addon”:true,“rejectUnauthorizedCerts”:true,“ha_boolean”:“y|yes|true|on|home|open”,“connectionDelay”:true,“cacheJson”:true,“heartbeat”:false,“heartbeatInterval”:“30”,“areaSelector”:“friendlyName”,“deviceSelector”:“friendlyName”,“entitySelector”:“friendlyName”,“statusSeparator”:“: “,“statusYear”:“hidden”,“statusMonth”:“short”,“statusDay”:“numeric”,“statusHourCycle”:“default”,“statusTimeFormat”:“h:m”,“enableGlobalContextStore”:false},{“id”:“5c9f2c63485dd599”,“type”:“alexa-remote-account”,“name”:“jaime”,“authMethod”:“proxy”,“proxyOwnIp”:“192.168.0.30”,“proxyPort”:“3456”,“cookieFile”:”/homeassistant/senha”,“refreshInterval”:“5”,“alexaServiceHost”:“pitangui.amazon.com”,“pushDispatchHost”:“”,“amazonPage”:“amazon.com.br”,“acceptLanguage”:“pt-BR”,“onKeywordInLanguage”:“on”,“userAgent”:“”,“usePushConnection”:“on”,“autoInit”:“on”,“autoQueryActivityOnTrigger”:“on”}]’‘’
