Galera, td bem?
Após atualizar o HA para versão 2022.5.2, a Integração com Alexa Media Player e Amazon Alexa deixaram de funcionar. Não carrega mais.
Alguém passando por isso?
Erro 1:
Logger: homeassistant.setup
Source: setup.py:162
First occurred: 14:43:41 (1 occurrences)
Last logged: 14:43:41
Setup failed for custom integration alexa_media: Requirements for alexa_media not found: [‘alexapy==1.25.3’].
Erro 2:
Logger: homeassistant.components.homekit.type_triggers
Source: components/homeassistant/triggers/numeric_state.py:75
Integration: HomeKit (documentation, issues)
First occurred: 14:43:50 (5 occurrences)
Last logged: 14:43:50
Error setting up trigger
File “/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py”, line 272, in call
return self._compiled([], data)
File “/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py”, line 818, in validate_callable
return schema(data)
File “/usr/src/homeassistant/homeassistant/helpers/config_validation.py”, line 146, in validate
raise vol.Invalid(f"must contain at least one of {expected}.")
voluptuous.error.Invalid: must contain at least one of below, above.
During handling of the above exception, another exception occurred:
File “/usr/src/homeassistant/homeassistant/components/device_automation/trigger.py”, line 74, in async_attach_trigger
return await platform.async_attach_trigger(hass, config, action, automation_info)
File “/usr/src/homeassistant/homeassistant/components/sensor/device_trigger.py”, line 151, in async_attach_trigger
numeric_state_config = await numeric_state_trigger.async_validate_trigger_config(
File “/usr/src/homeassistant/homeassistant/components/homeassistant/triggers/numeric_state.py”, line 75, in async_validate_trigger_config
config = _TRIGGER_SCHEMA(config)
File “/usr/local/lib/python3.9/site-packages/voluptuous/validators.py”, line 232, in call
return self._exec((Schema(val) for val in self.validators), v)
File “/usr/local/lib/python3.9/site-packages/voluptuous/validators.py”, line 355, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File “/usr/local/lib/python3.9/site-packages/voluptuous/validators.py”, line 351, in _exec
v = func(v)
File “/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py”, line 276, in call
raise er.MultipleInvalid([e])
voluptuous.error.MultipleInvalid: must contain at least one of below, above.
Alerta 1:
Logger: homeassistant.components.recorder.migration
Source: components/recorder/migration.py:101
Integration: Recorder (documentation, issues)
First occurred: 14:43:46 (1 occurrences)
Last logged: 14:43:46
Adding index ix_statistics_runs_start
to database. Note: this can take several minutes on large databases and slow computers. Please be patient!
Alerta 2:
Source: components/recorder/migration.py:75
Database is about to upgrade. Schema version: 25
Alerta 3:
Source: /usr/local/lib/python3.9/asyncio/events.py:80
First occurred: 14:43:33 (1 occurrences)
Last logged: 14:43:33
Setup of automation is taking over 10 seconds.
