Alguem pode me ajudar com esses erros no log
nem sempre eu acho o local obsoleto pra trocar, e quando acho fica com configuraçao inválida
Unable to find referenced entities light.led_banheiro
23:28:58 – (ALERTA) helpers/service.py
Template variable warning: No first item, sequence was empty. when rendering ‘{{ states.media_player | selectattr(‘attributes.last_called’,‘eq’,True) | map(attribute=‘entity_id’) | first }}’
23:28:52 – (ALERTA) helpers/template.py - a mensagem ocorreu pela primeira às 23:28:51 e apareceu 3 vezes
Setup of sonoff is taking over 10 seconds.
23:28:40 – (ALERTA) /usr/local/lib/python3.9/asyncio/events.py
Config entry ‘wled’ for wled integration not ready yet: Invalid response from API: Error occurred while communicating with WLED device at 192.168.0.58; Retrying in background
23:28:38 – (ALERTA) config_entries.py
The ‘value_template’ option is deprecated, please replace it with ‘state_value_template’
23:28:35 – (ALERTA) MQTT
Received message for unregistered webhook f19fdf06a6bedbcdbb4eba812701dfd0757cfa464cc2ae5ccc94880e9cc8f43f from 152.250.234.153
23:28:32 – (ALERTA) Webhook
The ‘entity_id’ option near /config/sensor.yaml:3 is deprecated, please remove it from your configuration
23:28:28 – (ALERTA) Template
Ola amigo ,eu tive essa mensagem e tambem não achei, porém parou tudo na data de ontem. Fiz atualização para o Tasmota 10 e corrigiu sozinho!
