Ajuda com botão e led
Preciso de ajuda para navegar entre os displays com os botões, e em seguida quero adicionar um led nele, não consegui encontrar muita coisa sobre isso.
substitutions:
esphome_name: esp32_ssd1306
esphome:
  friendly_name: Esp1
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
api:
  encryption:
    key: "74DyYNMsRqP/KnbCC90/nsbUfpHdx/8ruhphmCaX1Js="
ota:
  password: "4c2bc4519a2c8d18c96b7765303be11b"
wifi:
  ssid: "SINAL"
  password: "22221313"
  ap:
    ssid: "Esp1 Fallback Hotspot"
    password: "WBd6JI5tBEzO"
captive_portal:
i2c:
  - id: bus_a
    sda: 21
    scl: 22
    scan: true
  - platform: dht
    pin: GPIO13
    model: dht11
    temperature:
    humidity:
    update_interval: 20s
  - platform: bmp280
    temperature:
      name: "Outside Temperature"
      oversampling: 16x
    pressure:
      name: "Outside Pressure"
    address: 0x76
  - platform: uptime
    name: "${esphome_name} - Uptime Sensor"
  - platform: wifi_signal
    name: "${esphome_name} - WiFi Signal"
    update_interval: 60s
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: GPIO4
      mode: INPUT_PULLUP
    on_press:
      - lambda: id(display1).turn_on();
      - delay: 2s
      - lambda: id(display1).turn_off();
  - platform: gpio
    internal: true
    pin:
      number: GPIO2
      mode: INPUT_PULLUP
    on_press:
      - lambda: id(display2).turn_on();
      - delay: 2s
      - lambda: id(display2).turn_off();
  - platform: gpio
    internal: true
    pin:
      number: GPIO15
      mode: INPUT_PULLUP
    on_press:
      - lambda: id(display3).turn_on();
      - delay: 2s
      - lambda: id(display3).turn_off();
  - platform: gpio
    internal: true
    pin:
      number: GPIO12
      mode: INPUT_PULLUP
    on_press:
      - lambda: id(display4).turn_on();
      - delay: 2s
      - lambda: id(display4).turn_off();
  - platform: gpio
    internal: true
    pin:
      number: GPIO14
      mode: INPUT_PULLUP
    on_press:
      - lambda: id(display5).turn_on();
      - delay: 2s
      - lambda: id(display5).turn_off();
font:
  - file: "/config/esphome/Arial.ttf"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 16, id(my_font), "Acqua Callidus");
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(my_font), "Botão 3 - Umidade");
      it.printf(0, 16, id(my_font), "Botão 4 - Pressão");
      it.printf(0, 32, id(my_font), "Botão 5 - Temperatura");
    address: 0x3C
    lambda: |-
      it.printf(0, 16, id(my_font), "Humidity: %.2f%%", id(office_humidity).state);
    address: 0x3C
    lambda: |-
      it.printf(0, 32, id(my_font), "Pressure: %.2fhPa", id(outside_pressure).state);
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(my_font), "Temperature: %.2f°C", id(office_temperature).state);
switch:
    name: "${esphome_name} - Onboard LED"
    turn_on_action:
      - logger.log: "LED Ligado"
    turn_off_action:
      - logger.log: "LED Desligado"
